This D5 display shows CA PMO performance and monetary benefits during the current interval, which is the most recent period of CA PMO active time. You specify the maximum length of the current interval on the INTVL parameter. However, the time interval described on this display will always be shorter than the value of the INTVL parameter. This is because the current interval is still in progress when you invoked PMOMON, or printed this display as a batch job, or when you stopped CA PMO.
To view this D5 display, enter the following command from another D5 display:
CR
The following screen illustrates a sample D5 display for the current interval:
PMO 4.4 ( Active ) Sys=XE23 23MAR10:09:26:31 PMO Active Time= 1.514 hrs D5 Performance and Cost Savings Statistics (Curr Intvl) Start: 23MAR10:09:00:00 End: 23MAR10:09:30:13 LNKLST Private ----------Total---------- Curr Intvl Curr Intvl Curr Intvl Per Hour Library Searches 25,964 604 26,568 52,729 Resolved by PMO 20,975 386 21,361 42,394 % Library Searches 81 64 80 80 Elapsed Time Saved *** 2.59S 2.59S 5.11S CPU Time Saved 0.00S 0.00S 0.00S 0.00S EXCPs Saved 0 145 145 284 Money Saved on: Elapsed Time $ .00 .02 .02 .04 CPU Time $ .00 .00 .00 .00 EXCPs $ .00 .73 .73 1.44 ------------------- Total $ .00 .75 .75 1.48
Note: Each of the "Money Saved on" and "Total" fields were expanded to 12 characters (9,999,999.99) and now contain only one currency symbol on each line.
The column and row headings for this D5 display are discussed in the following sections unless they are described in the section D5: Performance and Cost Savings (Cumulative) in this chapter.
The Start and End fields on the Current Interval D5 display are described in the following:
The date and time that the current interval started.
The date and time that the current interval ended. This is when you invoked this display online, or when you printed it as a report, or when you stopped CA PMO.
The column headings on the Current Interval D5 display are described in the following:
Searches of LNKLST library directories during the current interval.
Searches of private library directories during the current interval.
All library directory searches during the current interval.
The average number of library directory searches per hour during the current interval.
Copyright © 2011 CA.
