Previous Topic: D5: Performance and Cost Savings (Cumulative)Next Topic: D5: Performance and Cost Savings (Current Interval)
D5: Performance and Cost Savings (Peak Interval)
This D5 display shows CA PMO performance and monetary benefits during the peak interval. The peak interval may be the period with the greatest number of library directory searches since CA PMO became active; if you specify the parameter RESETPK=YES, it is the most active period since midnight. The length of the peak interval depends on the value that you specify for the INTVL parameter.
Note: You can manually reset the peak interval with the F PMO,RESETPK command.
To view this D5 display, enter the following command from another D5 display:
PK
The following screen illustrates a sample D5 display for the peak interval:
PMO 4.3 ( Active ) Sys=XE23 23MAR10:09:26:31 PMO Active Time= 1.514 hrs D5 Performance and Cost Savings Statistics (Peak Intvl) Start: 23MAR10:07:55:39 End: 23MAR10:07:59:59 LNKLST Private ----------Total---------- Peak Intvl Peak Intvl Peak Intvl Per Hour Library Searches 13,026 1,516 14,542 201,863 Resolved by PMO 6,234 401 6,635 92,102 % Library Searches 48 26 46 46 Elapsed Time Saved 0.00S 2.69S 2.69S 37.33S CPU Time Saved 0.00S 0.00S 0.00S 0.00S EXCPs Saved 0 350 350 4,856 Money Saved on: Elapsed Time $ .00 .02 .02 .25 CPU Time $ .00 .00 .00 .00 EXCPs $ .00 1.75 1.75 24.26 ------------------- Total $ .00 1.77 1.77 24.55
Note: Each of the "Money Saved on" and "Total" fields were expanded to 12 characters (9,999,999.99) and now contain only one currency symbol on each line
The column and row headings for this D5 display are described in the following sections, unless they were discussed in the section D5: Performance and Cost Savings (Cumulative) in this chapter.
Start and End Fields
The Start and End fields on the Peak Interval D5 display are described in the following list:
Start
The date and time that the peak interval started.
End
The date and time the peak interval ended.
This display may show a shorter interval length than the one that you specified on the INTVL parameter. This happens if you invoke PMOMON before the time designated for the peak interval has elapsed. For instance, the peak interval may be shortened if you issue the F PMO,RESET command just before starting PMOMON.
Column Headings
The column headings on the Peak Interval D5 display are described in the following:
LNKLST Peak Intvl
Searches of LNKLST library directories during the peak interval.
Private Peak Intvl
Searches of private library directories during the peak interval.
Total Peak Intvl
Total searches during the peak interval.
Total Per Hour
The average number of searches per hour during the peak interval.
