Previous Topic: Using Split-Screen ModeNext Topic: Headers Common to All PMOMON Displays
Understanding the PMOMON Displays
PMOMON consists of the following displays, which are described briefly. The remainder of this chapter describes the displays in detail.
CA PMO Display Menu
A main menu that lists all of the PMOMON commands, including commands for invoking a display, scrolling through a display, printing the contents of a display, sorting the contents of a display, and ending a PMOMON session.
D0
PMO Parameters
A list of the current values for most CA PMO parameters.
D1
PMO Managed List
A display of the current contents of the managed list.
D2
BLDL/FIND Request Activity
Statistics on all BLDL/FIND requests issued on the system.
D3
LNKLST Library Searches—Summary
Statistics on directory searches of LNKLST libraries, and the elapsed time that CA PMO saved on these searches.
D4
LNKLST Library Searches—Detailed
Statistics on directory searches of LNKLST libraries, broken down by each library that was searched. This display also shows the elapsed time that CA PMO saved on these searches.
D5
Performance and Cost Savings
A set of three displays that show the cumulative savings of elapsed time, CPU time, and EXCPs by CA PMO; savings at the current time interval; and peak interval savings.
D6
Private Library Management Summary
Statistics on directory searches of private libraries, broken down by the CA PMO reasons for either managing or not managing these libraries.
D7
Private Library Searches—Summary
Statistics on directory searches of private libraries, and the elapsed time that CA PMO saved on these searches.
D8
Managed Private Library Searches—Detailed
Statistics on directory searches of private libraries that CA PMO is managing, broken down by volume or by library. This display also shows the elapsed time that CA PMO saved on these searches.
D9
Candidate Private Library Searches—Detailed
A list of private libraries that CA PMO is not currently managing, and the elapsed time that might be saved if you let CA PMO manage them.
D10
Library Same-System and Cross-System Updates
A display that shows how many updates were performed and what percentage of those were cross-system updates.
LS
Select LNKLST for Detail Statistics (D1/D4/D10)
A display that shows all active LNKLST sets and lets you select one to display detail statistics for on the D1, D4, and D10 displays.
