Previous Topic: Invoking PMOMON InteractivelyNext Topic: Understanding the PMOMON Displays
Using Split-Screen Mode
You can use split-screen mode if you completed the optional installation step Install the PMOMON ISPF Panel (see the CA PMO guide).
To split the screen so you can perform other tasks in ISPF, issue the SPLIT command (or press F14) from any PMOMON display. To switch to the other half of the screen, issue the SWAP command (or press F21).
