All of the PMOMON displays have the same header:
PMO 4.4 ( status ) Sys=ssss ddmmmyy:hh:mm:ss PMO Active Time=xx.xx tu
Dn Monitor Screen Title
This field is displayed if CA PMO was started on your system. It shows the CA PMO release number and activity status. If this field shows that CA PMO is "active," CA PMO is optimizing directory searches. If this field states that CA PMO is operating in "passive" mode, it is gathering information and displaying statistics as if it is active, but it is not actually optimizing directory searches. If this field shows that CA PMO was "disabled," CA PMO was stopped while it was running. For more information on CA PMO status, see the MODE parameter in the chapter "Using Parameters."
The four-character SMF system IDs of this system.
The current day, month, and year, and the current time shown in hours, minutes, and seconds.
The amount of time that CA PMO has been active, or the amount of time since you reset CA PMO statistics with the F PMO,RESET command. The variable xx.xx represents a number, and tu is a time unit such as days, hours, or minutes.
The number and title of the display.
Copyright © 2011 CA.
