Overview › How the Installation Process Works › How the Installation Process Works in InstallAnywhere Based install
For all supported platforms you can install using an InstallAnywhere based installer.
There are three InstallAnywhere installers:
- Windows
- Windows 64
- Multiplatform
This section outlines the basic steps needed for an InstallAnywhere install.
- Locate the installer for your platform.
Note: For more information about locating the platform, see Locating the Product Installer.
- Run the installer.
Note:
- (Optional) Migrate old CA OM Web Services 1.0 repository definitions to the new CA OM Web Services 2.0 installation.
- Configure your WAR or EAR file.
Note: For more information, see Configure CA OM Web Services.
- Setup your Java Web Application Server.
Note: For more information, see Preparing your Java Web Application Server.
- Deploy your CA OM Web Services war or ear file.
Note: For more information, see Deploying CA OM Web Services.
- Verify if CA OM Web Services is up.
Note: For more information, see Connectivity Test.
- Attempt accessing a report list and report data.
Note:
- For more information, see Retrieve a List of Reports.
- For more information, see Retrieve Report Data.
- Repository definitions and report list data dictionary entries must be setup during the configuration of your WAR or EAR file step to access data and report list.
