Previous Topic: Manual Connect Pool ConfigurationNext Topic: Install CCS Tomcat
Prepare your Java Web Application Server
CA OM Web Services is an application that runs in an HTTP/Application server and uses Axis2 for SOAP message handling. The installation and configuration of the HTTP/Application server is independent of CA OM Web Services. CA OM Web Services can be installed into existing implementations of supported servers.
For other InstallAnywhere based installs, Apache Tomcat (http://tomcat.apache.org) or IBM WebSphere can be used. For the SMP/E based install on the (USS) platform, Apache Tomcat from CA Common Services is used.
This topic covers setting up CA Common Services Apache Tomcat (CCS Tomcat) on the mainframe and IBM WebSphere considerations (if deploying a WAR file). For other platforms, refer to the documentation of your preferred web server.
If you are using CA OM Web Services on a distributed platform, you can proceed to Deploy CA OM Web Services.
