Previous Topic: Connectivity TestNext Topic: Setup Report List Test Tool
Retrieve a List of Reports
The report list command, Report_List_Test, is a test utility, which retrieves a list of reports accessible in a repository that is defined in CA OM Web Services. You can use the Configuration Tool to define Repositories. The report list command specifies the report name or document type, or both. The command retrieves reports matching these criteria and displays a limited subset of the report information/attributes.
The Report_List_Test command generates a list of reports for a specified repository that is defined in CA OM Web Services. The CA OM Web Services must be started to run this command. The Report_List_Test command runs through a Web Service request. It is not required to run on the same computer as the server where the CA OM Web Services is installed.
The information that is returned by the command includes the report name, a report description, an archive date, an archive time and optionally a report handle that identifies the report.
Note: The Repository definitions and report list data dictionary entries must be set up during configuring your WAR or EAR file step to access the data and report list.
This section includes:
