You must edit some configuration files to reflect the new website and port settings. Edit the configuration files to replace the HTTP connector with an HTTPS connector. You must also restart the CA Performance Center services so that the changes take effect.
cd/InstallationDirectory/CA/PerformanceCenter/PC
#/opt/CA/PerformanceCenter/PC/etc/jetty-ssl.xml
where '/opt/CA' is the default installation directory.
cd/InstallationDirectory/CA/PerformanceCenter/PC/etc
<?xml version="1.0"?>
<!DOCTYPE Configure PUBLIC "-//Jetty//Configure//EN" "http://www.eclipse.org/jetty/configure.dtd">
<Configure id="Server" class="org.eclipse.jetty.server.Server">
<Call name="addConnector">
<Arg>
<New class="org.eclipse.jetty.server.ssl.SslSelectChannelConnector">
<Set name="Port">8182</Set>
<Set name="maxIdleTime">30000</Set>
<Set name="Keystore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="Password">***PASSWORD***</Set>
<Set name="KeyPassword">***PASSWORD***</Set>
<Set name="truststore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="trustPassword">***PASSWORD***</Set>
<Set name="allowRenegotiate">true</Set>
</New>
</Arg>
</Call>
</Configure>
<Arg>
<New class="org.eclipse.jetty.server.nio.SelectChannelConnector">
<Set name="host"><Property name="jetty.host" /></Set>
<!-- Changed: Used to be Property -->
<Set name="port"><SystemProperty name="jetty.port" default="8181"/></Set>
<Set name="maxIdleTime">300000</Set>
<Set name="Acceptors">2</Set>
<Set name="statsOn">false</Set>
<Set name="confidentialPort">8443</Set>
<Set name="lowResourcesConnections">20000</Set>
<Set name="lowResourcesMaxIdleTime">5000</Set>
</New>
</Arg>
</Call>
cd/InstallationDirectory/CA/PerformanceCenter/PC/conf
wrapper.java.additional.2=-Djetty.port=8181
cd /InstallationDirectory/CA/PerformanceCenter/sso/webapps/ sso/configuration
<?xml version="1.0" encoding="utf-8" ?>
<Configuration>
<SingleSignOnEnabled>True</SingleSignOnEnabled>
<SingleSignOnProductCode>pc</SingleSignOnProductCode>
<SignInPageProductDefaultUrl>
<Scheme>https</Scheme>
<Port>8182</Port>
<PathAndQuery>/pc/desktop/page</PathAndQuery>
</SignInPageProductDefaultUrl>
<SingleSignOnWebServiceUrl>
<Port>8182</Port>
<PathAndQuery>/pc/center/webservice/sso</PathAndQuery>
</SingleSignOnWebServiceUrl>
</Configuration>
