By default, Single Sign-On uses Port 8381. To set up HTTPS, use the Single Sign-On Configuration Tool to update the default website scheme and port to match the encryption settings.
Perform the tasks in this procedure on every server where a data source is installed.
InstallationDirectory/CA/PerformanceCenter
You are prompted to select an option.
You are prompted to specify the priority.
Refers to settings that only administrators can change. Such settings are propagated to all other CA products registered to this instance of CA Performance Center. Remote Value settings are only used if a corresponding Local Override value is not present.
Refers to settings that can be changed for all products. If a Local Override value is present, it takes precedence over both the Remote Value and default settings.
You are prompted to select a property to configure.
Now you must configure CA Performance Center files to use HTTPS.
