Edit some startup files to support SSL encryption in Single Sign-On. You must also restart all CA Performance Center and Single Sign-On services to update the settings.
InstallationDirectory/CA/PerformanceCenter/sso
#/opt/CA/PerformanceCenter/sso/etc/jetty-ssl.xml
where '/opt/CA' is the default installation directory.
InstallationDirectory/CA/PerformanceCenter/sso/etc
<?xml version="1.0"?>
<!DOCTYPE Configure PUBLIC "-//Jetty//Configure//EN" "http://www.eclipse.org/jetty/configure.dtd">
<Configure id="Server" class="org.eclipse.jetty.server.Server">
<Call name="addConnector">
<Arg>
<New class="org.eclipse.jetty.server.ssl.SslSelectChannelConnector">
<Set name="Port">8382</Set>
<Set name="maxIdleTime">30000</Set>
<Set name="Keystore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="Password">***PASSWORD***</Set>
<Set name="KeyPassword">***PASSWORD***</Set>
<Set name="truststore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="trustPassword">***PASSWORD***</Set>
<Set name="allowRenegotiate">true</Set>
</New>
</Arg>
</Call>
</Configure>
<Arg>
<New class="org.eclipse.jetty.server.nio.SelectChannelConnector">
<Set name="host"><Property name="jetty.host" /></Set>
<!-- Changed: Used to be Property -->
<Set name="port"><SystemProperty name="jetty.port" default="8181"/></Set>
<Set name="maxIdleTime">300000</Set>
<Set name="Acceptors">2</Set>
<Set name="statsOn">false</Set>
<Set name="confidentialPort">8443</Set>
<Set name="lowResourcesConnections">20000</Set>
<Set name="lowResourcesMaxIdleTime">5000</Set>
</New>
</Arg>
</Call>
InstallationDirectory/CA/PerformanceCenter/sso/conf
wrapper.java.additional.2=-Djetty.port=8381
service caperfcenter_console stop
service caperfcenter_devicemanager stop
service caperfcenter_sso stop
service caperfcenter_sso start
service caperfcenter_devicemanager start
service caperfcenter_console start
