Preparing Linux Servers › Verify that the Linux Servers Are Prepared
Before you begin the upgrade, verify that the following conditions are met. Failure to comply with these requirements can result in data loss, increased down time, software conflicts, or a failed upgrade.
- System Requirements: Verify that the upgrade servers meet the Linux requirements and recommendations.
- Software Requirements: Verify that the upgrade servers have fully operational CA Network Flow Analysis software that is supported for upgrade.
- Verify that each of the Harvester Linux servers is ready for the upgrade by:
- To support non-Latin characters such as Japanese and Simplified Chinese, any command line clients that you use for installation must be configured for UTF-8 encoding. If UTF-8 encoding is not enabled, these characters may not display properly.
- The appropriate language packs are required for localized deployments.
- Regional Settings must use a period (.) to indicate a decimal value. If your deployment is localized to French, change the decimal symbol to a period in the Region and Language: Customize Format dialog.
- Polling fails if DNS resolution is not configured. For more information, see the Readme.
