Before you upgrade, back up the databases and files that are listed in the following table.
Important:
Database |
Stand-Alone |
Harvester (Distributed) |
NFA Console (Distributed) |
DSA Server (Distributed) |
Anomaly Detector |
reporter: Enterprise Overview data; NFA console configuration data |
Important |
Important |
harvester: Harvester configuration data |
Important |
Important |
nqrptr: Configuration for collecting historical (15-minute) data |
Important |
nsas: Anomaly Detector configuration data |
Important |
poller: Poller configuration data |
Important |
Important |
ReaperArchive15: Historical (15-minute) data |
Recommended |
Recommended |
Recommended |
Customized Files: Configuration or other files that have been customized |
Important |
Important |
Important |
Important |
Customized data_retention: Settings to regulate data retention |
Important if customized |
ReaperArchive: Realtime (1-minute) data |
Optional, rarely backed up |
The following list describes the databases and their locations:
Path: <install_path>\MySql\data\reporter directory
Path: <install_path>\MySql\data\harvester directory
Path: <install_path>\MySql\data\nqrptr directory
Path: <install_path>\MySql\data\nsas
Path: <install_path>\MySql\data\poller directory
Path: <install_path>\Netflow\datafiles\ReaperArchive15 directory
The CA Network Flow Analysis configuration files typically have a .config, conf., or .ini extension and are located in the product installation path. Other customizations may include .css files and report logos.
Path: <install_path>\Netflow\datafiles\ReaperArchive directory
Path: <install_path>\MySql\data\data_retention directory
