For a distributed deployment, CA Network Flow Analysis supports running the Harvester on dedicated Linux servers that meet the following system requirements:
Appropriate language packs installed on all servers for localized deployments
We recommend that Linux Harvester servers meet the following specifications:
If you do not have enough available space in the /tmp directory and you cannot configure it, relocate the directory. Export the IATEMPDIR environment variable (for the Install Anywhere temporary directory) to set a new location, and select a directory with sufficient space.
Notes:
