Preparing Windows Servers › Verify that the Windows Servers Are Prepared
Before you begin the upgrade, verify that the following conditions are met. Failure to comply with these requirements can result in data loss, increased down time, software conflicts, or a failed upgrade.
Verify that the following conditions are met:
Stand-Alone Server
Distributed NFA Console Server
Distributed Harvester Server
Distributed 3-Tier DSA Server
- (Recommended) Remote Desktop connection is enabled to allow remote access
- Static IP address is assigned to each server. Set the Harvester server IP address to match the flow export destination that is assigned to each router.
- The following third-party software is disabled until the upgrade is complete: Antivirus, server monitoring, and maintenance software. If you enable antivirus scans later, exclude the CA Network Flow Analysis installation path and its subdirectories.
* The upgrade program does not open or does not complete successfully unless this requirement is met.
** If the server fails to pass this check, a warning message opens.
General Notes:
- Stop other programs from running during the installation or upgrade.
- When you apply Windows updates, restart all servers to ensure that the updates are applied.
- Ensure that no one else is logged in to the server during the installation or upgrade.
Localization Notes:
- To support non-Latin characters such as Japanese and Simplified Chinese, any command line clients that you use for installation must be configured for UTF-8 encoding. If UTF-8 encoding is not enabled, these characters may not display properly.
- The appropriate language packs are required for localized deployments.
- Regional Settings must use a period (.) to indicate a decimal value. If your deployment is localized to French, change the decimal symbol to a period in the Region and Language: Customize Format dialog.
