Make sure the NFA console server or stand-alone server is registered as a data source for one of the following:
If you need to upgrade CA Performance Center, upgrade it now. For instructions, see the CA Performance Center Installation Guide.
If CA Network Flow Analysis is not registered as a data source, some of the function links on the Administration page are disabled. For instructions about registering, see the CA Network Flow Analysis Administrator Guide topic "Register CA Network Flow Analysis." After you register, review the results in the Performance Center Console and the NFA console. Make any adjustments that are needed.
