This release does not support connections to IPv6-formatted addresses. This topic describes how to set up Windows Server 2008 systems so that they do not connect to IPv6 addresses. If connection to IPv6-formatted addresses is enabled, data collection fails.
Required/Optional |
Servers to Configure |
Recommended |
All servers |
The instructions are based on the assumption that each server has a single network interface card, which is the recommended configuration.
The Network Connections window opens and shows the currently configured connections.
The Properties dialog opens.
The dialog closes and your changes are saved.
The window closes.
