In most cases, the status indicates that data source registration has completed successfully. If the status indicates an error, use the test feature on the Manage Data Sources page (CA PC) or Data Source List page (NPC).
The Test button initiates a test to confirm that a new data source is registered and connected correctly. The test checks for version compatibility and verifies that the data source is not registered with a different instance of the software.
If the test fails, verify that the DNS hostname or IP address of the data source server is correct.
