Initial Configuration › Configure the Product to Work with Performance Center
To complete some essential administration tasks, you must register CA Network Flow Analysis with Performance Center (either CA Performance Center or CA NetQoS Performance Center). Once you register the product and complete the administration tasks, operators can see meaningful reports in the NFA console and in the Performance Center Console.
To configure CA Network Flow Analysis properly, you must perform the following tasks:
- Register the product as a data source for Performance Center.
- Set up the following elements in the Performance Center Console:
- SNMP profiles
- (Optional) IP domains
- User accounts, permissions, and roles
- (Recommended) Groups
- Configure flow collection
- Add Harvesters.
- (Three-tier distributed architecture only) Add DSAs.
- Enable the routers and interfaces to export flows.
- (Optional) Configure traps.
- (Optional) Verify that CA Network Flow Analysis is receiving data.
These tasks are described in the following topics.
This section contains the following topics:
Register CA Network Flow Analysis
Test Data Source Connections
Verify SNMP Profiles
Verify IP Domains
Configure Flow Collection
Verify That Data Is Received
Change the Domain of Interfaces and CVIs
Configure Traps
Set Up User Accounts
Set Up Groups
Results of Unregistering
