Register the product in the Performance Center Console--on the Manage Data Sources page (CA PC) or the Data Source List page (NPC).
Note: For information about the number of data sources that you can use, see the Release Notes for your Performance Center version.
The current list of registered data sources are shown on the Manage Data Sources page (CA PC) or the Data Source List page (NPC).
The Add Data Source dialog opens.
Note: All CA products that can be registered as data sources are shown in the Source Type list. The list is not filtered to hide products that are installed already.
The hostname is the IP address or DNS hostname of the server that hosts the database for the data source. For a distributed deployment of the product, enter the hostname of the NFA console or stand-alone server.
For more information about the port setting, see the CA Single Sign-On User Guide.
Note: For more information about using SSL for communication between the product and Performance Center, see the CA Single Sign-On User Guide.
If you do not enter a name, a default name is created by combining the data source type and hostname. For example, you can use a default name like NetworkFlowAnalysis@xxx.x.x.xx or you can use a name like NetworkFlowAnalysis_NewYork.
The updated list shows the data sources that are registered.
