Use the Site to Site wizard to create a site to site report step by step. The wizard guides you to select many options, such as the sites involved in the report, the report schedule, the data resolution (1-minute or 15-minute), and the reporting period.
- Select Site to Site from the NFA console menu.
- Click Create New Report.
The Site to Site Report Wizard opens and shows the options Create a new Site to Site report and Copy an existing report.
- Click Create a new Site to Site report and click Next.
Note: Alternatively, you can select the Copy an existing report option and modify an existing report.
The Select Sites page opens.
- Select at least two sites for the report. You can either select an existing site or sites, or create a new site definition.
To create a new site definition:
- Click Create Site.
- Enter Site Name, Site Description (optional), Network Name, and Subnet.
- (Optional) Click Add Another Network to add additional networks to the site definition.
- Click Save.
The selected sites are added to the site list.
- Click Next.
The Specify Schedule page opens.
- Select the type of reporting period from the Period list in the Specify Schedule page:
- duration: Limits the reporting period to an amount of time, ending at the time the report runs. Enter the number of time units in the Last box.
Select a unit of time from the list (days, weeks, months, or years).
You can set up a schedule for a duration report or you can run the report on demand.
- start & end: Specify a Start date and End date either by using the calendar icons or by selecting hour and time values from the lists. Hour values are expressed in 24-hour format.
- Select the data resolution (1-minute or 15-minute) in the Resolution box.
Note: 1-minute data resolution is limited to no more than 30 days, based on the storage allocated to your NFA system. If a duration of more than 30 days is required, use 15-minute data to get more complete results.
- (Optional) Select the Schedule check box and specify the following options:
- Schedule: Select the type from the Schedule list (Daily, Weekly, Monthly, Quarterly, Yearly).
- Daily: Select the day or days of the week, time of day, and time zone for report generation.
- Weekly: Select the day of the week, time of day, and time zone for report generation.
- Monthly: Select either the date or the week in the month and day of the week. Select the time of day, and time zone for report generation.
- Quarterly: Select a month that ends the first reporting quarter, time of day, and time zone.
- Yearly: Select a month that ends the first reporting year, time of day, and time zone.
Note: The options in the Recurrence section are available only if you select 'duration' as the reporting period type.
- (Optional) Enter the email addresses of all the report recipients in the format name@domain. Separate multiple addresses with a comma or semi-colon.
- Click Next.
The Enter Name page opens.
- Identify the report and its location:
- Folder: Accept the default folder or select a different folder to contain the new report.
- Name: Give the new report a name, which appears in the Reports list.
- Description: (Optional) Add a description to help identify the report. For example, use the description to identify scheduled reports and to indicate distinguishing features of Duration reports.
Click Next. The Summary & Submit page opens.
- Review the information in the Report Definition Summary.
- Save: Save the report definition and return to the Site to Site page.
- Save and Queue Report: Queue the report to run and return to the Site to Site page.
