Previous Topic: Site to Site ReportsNext Topic: Create a Site to Site Report
Open the Site to Site Page
When you click the Site to Site tab, the Saved Report Folders pane is displayed on the left and any existing reports are displayed on the right.
You can perform the following tasks in the Saved Report Folders pane: create folders, rename folders, and delete custom folders. You cannot delete the default Site to Site Reports folder, which is built in to CA Network Flow Analysis. Create additional folders to provide more extended organization for your Site to Site reports.
The right pane displays the Site to Site report definitions in the currently selected folder. Use the links at the top and bottom of the pane to delete or run selected reports, as well as to create or move reports.
