Site to Site reports enable you to view volumes of data between two or more sites. A site may be defined as a collection of subnets that can also be discontiguous.
Use Site to Site reports to compare bytes in, rate in, bytes out, and rate out between pairs of sites. You can export the displayed data to a file in comma-separated value (CSV) format.
The reports may be configured for:
You can use saved report definitions to generate an updated report at any time. As the number of reports grows, use the folder management system to keep the reports organized and accessible.
This section contains the following topics:
Define Site to Site Report Periods and Schedules
Move a Report to Another Folder
