This section describes how to create and manage protocol groups, ToS labels, ToS groups, and customized autonomous system (AS) names. You use a number of different pages to perform the functions.
Protocol Group Configuration Page
You can use the Protocol Group Configuration page to view the existing protocol groups and their contents. You can add, edit, and delete custom protocol groups.
Select Groups: Protocol Groups from the Administration page, then use the Protocol Group Configuration page to perform the following main tasks:
ToS Configuration Page
You can use the ToS Configuration page to view and edit the labels and descriptions for ToS values.
Select Define an Application: ToS Names from the Administration page, then use the ToS Configuration page to perform the following task:
ToS Group Configuration Page
You can use the ToS Group Configuration page to view the existing ToS groups and their contents. You can add, edit, and delete custom ToS groups.
Select Groups: ToS Groups from the Administration page, then use the ToS Group Configuration page to perform the following main tasks:
AS Names Page
You can use the AS Names page to view and edit AS names.
Select Groups: AS Names from the Administration page, then use the AS Names page to perform the following main tasks:
