You can create labels (or descriptions) for ToS values to ensure that operators know which service or application the ToS values represent. If you do not label ToS values, the numeric ToS value is displayed by default.
Note: The ToS labels that you create affect all uses of the ToS in the assigned domain, but do not affect ToS labels in other domains. ToS labels are domain-specific in a deployment that has multiple domains.
The ToS Configuration page opens and displays information about the selected ToS and domain.
The Description becomes editable.
Your change is saved and the Description and Value fields for the selected ToS are updated.
Note: You can also use the ToS Configuration page to add or delete ToS values to ToS groups. Select the domain and the ToS value, then click the Add/Remove link at the top of the ToS groups list. The ToS Group Index dialog opens, which you use to make changes for user-configured groups. (You cannot change the built-in All ToS group.)
