Customize AS names as needed to make interface report labels more user-friendly.
In a multi-domain environment, AS names are domain-specific. In this case, changes to AS names affect reports about interfaces in the selected domain.
The Edit AS Number Description dialog opens.
The Old Name value is the official (base) name for the AS, which cannot be edited.
The name that you specified appears in the Description column for the selected AS number. All custom AS names are shown in bold.
The updated AS names also appear in labels and other references in the following CA Network Flow Analysis Interface views:
Note: To restore the AS name to its official value, click Reset on the appropriate row, then OK in the confirmation box that opens.
