Add a user account for each person who will operate the products. For security purposes, operators should not share user accounts.
Note: This topic describes the steps to perform this task in CA Performance Center. If you register CA Network Flow Analysis as a data source for CA NetQoS Performance Center, the steps are slightly different.
The current list of user accounts is displayed.
The Create New User wizard (CA PC) or Add User page (NPC) opens.
Is a login name for the user account. Limited to 50 characters.
(Optional) Describes the user account to help you identify it.
(Optional) Associates an email address with the user account.
Specifies the language spoken by the operator associated with the user account.
Identifies the authentication method that applies to this user account. The method must match Single Sign-On configuration. Select one of the following:
Defines a password for the user account. The password is limited to 32 characters.
Corresponds to the time zone in which the user will view data.
Default: UTC (Coordinated Universal Time).
Is the role assigned to the user account.
Determines whether the account is activated for use (Enabled).
Determines whether the account is activated for use (Enabled) and whether the user is allowed to share views with other products (Allow user to generate view URLs).
The new user appears in the list of user accounts.
