Each registered data source has its own product privilege setting, which grants unique privileges within that product interface. Administrators give users product privileges for each data source. For example, the product privilege determines whether a user can log in to CA Network Flow Analysis or drill down from a Performance Center view to details in the NFA console. Privileges are specific to the data source instance.
The default administrator account, admin, is locked to prevent changes to product privileges. This account must have Administrator privileges for all registered data sources. If you select a group of accounts that includes the admin account, you cannot edit the product privileges for any of the selected accounts.
A user must have product privileges for the CA Network Flow Analysis data source to log in to the NFA console. Product privileges also determine whether a user can access the Administration page, and can perform certain functions:
Gives access to the Administration page in the NFA console and to all functions. Functions include creating and managing user accounts, roles, groups, SNMP profiles, and scheduling for reports.
Gives user-level access and any additional abilities that the Role setting grants. For CA Network Flow Analysis, the Power User privilege is equivalent to the Administrator privilege.
Gives access to Top Interfaces reports and Interface Utilization reports on the Enterprise Overview page.
A User with the appropriate Permission Group settings also has access to the following reports:
The Role and Permission Group settings determine whether the User also can run existing reports, create reports, and manage reports. To create reports, a User must have access to All Groups.
Has no access to a data source. The user who has this product privilege cannot log in to the NFA console or drill down from a Performance Center view to the NFA console. By default, all users have this product privilege setting for all data sources.
Note: The same user account can have different privileges for different data sources.
