Custom Reports › Manage Custom Reports › Rename a Report Folder
You can change the name of a report folder, including the name of the default report folder.
- Navigate to the page for the report type: Custom Reporting, Flow Forensics, Analysis, or Site to Site.
- In the Saved Report Folders pane, select the check box next to the report folder that you want to rename.
- Click Rename.
A pop-up dialog opens.
- Enter a new name for the folder in the pop-up dialog.
- Click OK.
The dialog closes. The new report folder name appears in the Saved Report Folders pane.
