Custom Reports can answer specific technical and business questions in your environment, such as the following questions:
To get started, select Custom Reporting from the NFA console menu.
The Create New Report page opens, which lists the existing reports. If you have the required permissions, the page contains functions for creating, managing, and running Custom Reports. You can generate updated versions of reports, add new report definitions, and change report settings.
The Create New Report page includes the following functions:
Saved Report Folders:
Reports:
This section contains the following topics:
