Previous Topic: Manage Custom ReportsNext Topic: Rename a Report Folder
Create a Report Folder
Create your own report folders to group reports. For example, you can use folder names to identify the purpose for a set of reports.
  1. Navigate to the page for the report type: Custom Reporting, Flow Forensics, Analysis, or Site to Site.
  2. Click New at the bottom of the Saved Report Folders pane.
    A pop-up dialog opens.
  3. Enter a name for the new folder in the pop-up dialog.
  4. Click OK.
    The dialog closes and the new folder appears in the Saved Report Folders pane.
