Previous Topic: Top Hosts (Bar)Next Topic: Top Hosts (Table)
Top Hosts - Pie
The Top Hosts (Pie) views show the hosts that account for the highest volumes of network traffic on the selected interface. The example graphic shows the view in the CA Performance Center Console.
The Top Hosts (Pie) view shows the hosts who send the most traffic to or from an interface.
The table includes the following information by default:
Identifier
Identifies the interface that is used for the report. The identifier string consists of the router name, interface name, and interface description (under the view title).
(NPC) The identifier line also includes the interface speed.
Host Name
Identifies the host server by its fully qualified DNS name (if available) and IP address.
Total
Records the total amount of data for the host on the interface, expressed in a scale that is appropriate for the highest-volume host.
Percent
(CA PC) Records how much the host consumes out of the total traffic that is displayed.
Performance Center views show the data from the time range that is defined for the page.
Opening the Views
To see these views in the Performance Center Console, go to one of the following locations:
Available Actions
You can perform several actions in this view, including the following ones:
Find Host Pie Charts in the NFA Console
You can display pie charts with host volumes in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
