Previous Topic: Uninstall the SoftwareNext Topic: FIPS Algorithm Policy Is Enabled
Troubleshooting
This section provides some troubleshooting tips for problems that prerequisite tests detect. Prerequisite tests can generate warnings or failure notices. If you receive a warning, you can correct the problem immediately or wait until the installation or upgrade software runs. You must correct a failure before you can continue. Most of the troubleshooting topics describe prerequisite failures.
Note: Prerequisite tests often rely on general indicators to identify problems. Passing a prerequisite test is not a guarantee that everything is configured properly. It is important to meet all of the requirements and complete the configuration tasks that are described in this guide.
The following prerequisite tests are run:
Test
Description
Warning or Failure
Server
Browser
Checks the Registry for a browser. Verify that a supported browser version is installed.
Warning
Stand-alone or NFA console
DEP
Verifies that the winmgt service is running. Configure DEP as described in this guide.
Warning
Windows servers
Verifies that the FIPS Algorithm policy is not enabled.
Verify automatic fix or Failure
IIS Installed
Verifies that the wcsvc service is running. Install and configure IIS as described in this guide.
Warning
IIS Version
Checks the Registry for IIS version 7.0.
Warning
Java Version
Verifies that the supported version of the Java Runtime Engine is installed.
Failure
All servers
.NET 3.5 Version
Checks for .NET version 3.5 SP1. If version 3.5 is found, turns on SP1.
Failure
.NET 4.0 Version
Verifies that .NET version 4.0 is not installed.
Failure
Service Control command
Verifies that the Windows System32 directory contains the sc.exe file.
Failure
Windows servers
SNMP
Verifies that the snmp service is running and the process ID is present. Configure SNMP on Windows servers and Linux servers.
Warning
All servers
Windows 2003 Detected
Verifies that the server is running Windows Server 2008, not Windows Server 2003.
Failure
Windows servers
This section contains the following topics:
Java Is Not Installed
SC.exe Is Not Installed
SNMP Is Not Enabled
Windows Server 2003 Found
