Previous Topic: Uninstallation PrerequisitesNext Topic: Troubleshooting
Uninstall the Software
This topic describes how to uninstall the CA Network Flow Analysis software by using the Uninstaller. You also can uninstall the software from the Windows Add or Remove Programs window, where it is listed under the publisher CA Technologies, Inc.
  1. Log in as a user who is a member of the Administrators group.
  2. Back up your data and configuration files. For information about this step, see the CA Network Flow Analysis Administrator Guide.
  3. Exit from all applications--with no exceptions.
  4. Start the Uninstaller: Double-click the Uninstaller shortcut in <install_path>\Uninstall:
    The Uninstall window opens.
  5. Click Uninstall.
    The Uninstaller removes all of the program and data files, including the following CA Network Flow Analysis and MySQL elements:
    When the process is complete, the screen displays a list of the directories and files that were not deleted.
    Note: Leave the file system undisturbed while uninstallation is in progress. Do not attempt to view the progress in Windows Explorer, for example.
    Once the program finishes, the Uninstall Complete screen opens.
  6. Click Done to close the Uninstall Complete screen.
  7. Wait a few minutes to allow the helper process to finish the final cleanup.
    Some files are not deleted until this phase is finished. Once the final cleanup is finished, the Uninstaller itself is deleted.
Notes:
