Previous Topic: Add Role Rights for UsersNext Topic: Assign Product Privileges
Assign Permission Groups to User Accounts
Individual operators require data access permissions to monitor data in the products. Access permissions are based on groups. You can assign access permissions according to your plan for custom groups. Your goal as the administrator is to make sure that all operators see only the data they require to do their job.
For example, suppose you create custom groups and assign them as permissions to IT staff. When staff members log in to CA Performance Center or CA NetQoS Performance Center, they can view data from the systems that are assigned to them.
  1. Log in to the Console for CA Performance Center or CA NetQoS Performance Center as a user with administrative privileges.
  2. Click Admin, User Settings: Users.
    The Manage Users page (CA PC) or User List page (NPC) opens.
  3. Select a user account that you want to change, and click Edit.
    The Edit User wizard or dialog opens.
  4. Display the permission groups:
    The group settings are displayed.
  5. Add permission groups to the user account
    The selected permission groups appear in the Selected Groups pane.
  6. Select the default group for the user--the data that appears by default in the dashboards for the user:
  7. Click Save.
    The changes are saved to the user account, and you return to the Manage Users page.
    When the user logs in, data from the default group appears in dashboards by default.
