Initial Configuration › Configure CA Network Flow Analysis to Work with Performance Center
To complete some essential administration tasks, you must register CA Network Flow Analysis with CA Performance Center or CA NetQoS Performance Center. Once you register CA Network Flow Analysis and complete the administration tasks, operators can see meaningful reports in both locations.
To configure CA Network Flow Analysis properly, you must perform the following tasks:
- Register CA Network Flow Analysis as a data source for CA Performance Center or CA NetQoS Performance Center.
- Set up the following elements in CA Performance Center or CA NetQoS Performance Center:
- SNMP profiles
- IP domains
- User accounts, permissions, and roles
- Groups
- Configure flow collection
- Add Harvesters.
- (Three-tier distributed architecture only) Add DSAs.
- Enable the routers and interfaces to export flows.
- Verify that CA Network Flow Analysis is receiving data from the interfaces.
These tasks are described in the following topics.
This section contains the following topics:
Test Data Source Connections
Verify SNMP Profiles
Verify IP Domains
Configure Flow Collection
Verify That Data Is Received
Change the Domain of Interfaces and CVIs
Configure Traps
Set Up User Accounts
Set Up Groups
Results of Unregistering
