Previous Topic: Installing the SoftwareNext Topic: Upgrade a Standalone Server
Prerequisites
Before you install or upgrade the CA Network Flow Analysis software, perform the following tasks:
Note: If you exit from the upgrade program before the upgrade is completed, then restart the upgrade, the program resumes from your last saved change. The program does not start over from the beginning.
