A standalone deployment consists of a single server that hosts all of the components: the Harvester and the NFA console. Complete the steps in this topic to install the Harvester and NFA console on a single Windows server or virtual machine.
Note: A standalone upgraded deployment of CA Network Flow Analysis 9.1.2 uses a two-tier architecture, even if you previously had a standalone deployment with three-tier architecture.
Before You Begin: Verify that the installation server meets the following requirements:
Follow these steps to complete the Harvester phase of the upgrade:
The Console tool prepares the system for the upgrade.
java -jar consoletool-exe.jar
To launch the Console tool by double-clicking the file, Windows Explorer must have the correct association for .jar files.
The ConsoleInfoToPollerTool<yyyy-mm--dd>.log file opens when the Console tool completes--whether the tool completes successfully or fails. The log is saved in the <NFA_install_path>\Reporter\Logs\ directory.
The Console tool cannot complete successfully if the system has undeployed interface aggregations or unscheduled merge or delete interface tasks. If the tool does not complete successfully, note the error messages in the log file and contact CA Support.
The pump service stops.
A check verifies that the installation server has a supported version of the Java Runtime Engine (JRE) installed. If the check fails, an error message opens. You cannot launch the upgrade program until this problem is corrected.
If the server passes the Java prerequisite check, the program starts and the language selection screen opens.
The Welcome screen opens.
The CA NFA Harvester License Agreement screen opens.
Prerequisite tests are run to identify problems on the server. If a a problem is found, an error message opens. A critical problem causes the program to exit. A Pre-requisite Check Warning message or other warning message opens for non-critical problems, which gives you the option to make corrections now or after the installation or upgrade is complete.
Your system is tested to determine whether the installed version of CA Network Flow Analysis is supported for upgrade. If a supported version is located, the Upgrading Existing Installation message opens.
Once the server passes the required checks and you close any warning messages that appear, the Choose Install Folder screen opens. This screen displays the original root installation path as the default setting.
Important: If you do not use the original installation path, the upgraded software will not run properly.
If the program does not find certain expected directories in the installation path, an error message opens and the upgrade stops. This problem does not occur when the previous software installation is fully functional.
The Select a Location for the MySQL Data Directory screen opens after a moment. This screen shows the original installation path for the MySQL data directory.
The Select a Location for the MySQL Temp Directory screen opens, which shows the original installation path for the MySQL tmp directory.
MySQL51 is configured, then the Pre-Installation Summary screen opens.
The Installing Harvester screen opens, which shows the progress. When the upgrade is complete, the Install Complete screen opens and reports any errors that occurred.
The Harvester upgrade program closes.
Follow these steps to complete the NFA console phase of the upgrade:
A check verifies whether a supported version of the Java Runtime Engine (JRE) is installed. If the check fails, an error message opens. You cannot launch the upgrade program until this problem is corrected.
The NFA Console License Agreement screen opens.
The Third-Party License Agreement screen opens.
Prerequisite tests are run on the installation server. If an error message opens that requires attention, see Troubleshooting.
A test verifies that the installed version of CA Network Flow Analysis is supported for upgrade. The Singlebox Confirmation message opens when the verification is complete. This message asks you to confirm that you want a standalone deployment of CA Network Flow Analysis.
The Pre-Installation Summary screen opens after a moment.
The Installing NFA screen opens. Progress is shown in the status bar and messages. When the NFA console upgrade is complete, the Install Complete screen opens.
The upgrade program closes after a moment. If you selected the option to restart now, the system restarts and the upgrade is finalized.
If you upgraded from ReporterAnalyzer 9.0.1, migration of DSA database table data begins as soon as the CA NFA DSALoader service restarts. If you have many agents and an extensive amount of stored data, migration may continue for some time. When migration is complete, the CA NFA DSALoader service stops itself and does not restart. The service state change is recorded in the following log: \Netflow\Logs\dsaLoaderErrors-<yyy-mm-dd>.log. Reports have limited access to historical (15-minute) data until the migration is complete.
Note: The revision history shows that the software is upgraded to the correct version. To display the revision history, complete the following substeps:
Next: Complete the post-upgrade tasks.
