Preparing Linux Servers for the Upgrade › Prepare the Linux Servers
Before you begin the upgrade, verify that the following conditions are met. Failure to comply with these requirements can result in data loss, increased down time, software conflicts, or a failed upgrade.
- System Requirements: Verify that the installation servers meet the requirements described in Linux Operating System Requirements.
- Software Requirements: Verify that the installation servers have fully operational installations of CA Network Flow Analysis software that is supported for upgrade.
- Verify that each of the Harvester Linux servers is ready for the upgrade by:
- Installing the supported version of the JRE: Java Runtime Engine (JRE) 1.6u41.
Notes:
- To support non-Latin characters such as Japanese and Simplified Chinese, any command line clients that you use for installation must be configured for UTF-8 encoding. If UTF-8 encoding is not enabled, these characters may not display properly during installation.
- The appropriate language packs are required for localized deployments.
