Preparing Windows Servers for the Upgrade › Unregister from CA Performance Center
CA Performance Center 2.2.00 is required for CA Network Flow Analysis 9.1.2. You can upgrade to CA Performance Center 2.2.00 from 2.1.00, but not from earlier CA Performance Center versions. Your next step depends on your current version of CA Performance Center or NetQoS Performance Center, as described in the following table.
If you need to unregister, complete the steps in this topic before you you start the CA Network Flow Analysis upgrade. If you are able to upgrade your installation of CA Performance Center to version 2.2.00, complete that upgrade after you upgrade CA Network Flow Analysis.
Customizations are lost when you unregister and register again. Read this topic carefully to prepare for these events.
Pre-Upgrade NFA Version
Pre-Upgrade NPC or CA PC Version
How to Upgrade to CA PC 2.2.00
NFA 9.1.1
CA PC 2.1.00
1) Upgrade CA Network Flow Analysis.
2) Upgrade your installation of CA Performance Center to version 2.2.00. For instructions, see the "Upgrade Procedures" section in the CA Performance Center Installation Guide.
NFA 9.1.1
CA PC 2.0.00
1) Unregister as a data source.
2) Upgrade CA Network Flow Analysis.
3) Register as a data source with CA Performance Center 2.2.00.
NFA 9.1.0
CA PC 2.0.00
RA 9.0.161
NPC 6.1.x
We generally do not recommend unregistering from CA NetQoS Performance Center or CA Performance Center. We recommend that you unregister only when you need to run the newer version of CA Performance Center and your version of CA Performance Center or CA NetQoS Performance Center cannot be upgraded.
Results of Unregistering:
If you unregister CA Network Flow Analysis from NetQos Performance Center 6.1.x or CA Performance Center 2.0.00 and register again with CA Performance Center 2.2.00, the following rules apply:
- Domains:
- The default domain is retained. Groups, users, devices (routers), interfaces, protocol names, and ToS labels that are assigned to the default domain retain their assignments.
- Custom domains are deleted.
- Groups, users, devices (routers), and interfaces in custom domains are reassigned to the default domain.
- Protocol names, ToS labels, AS names, and IP addresses in custom domains become inaccessible.
- User accounts:
- User accounts are retained if the users have valid product privilege settings (User, Power User, or Administrator) for CA Network Flow Analysis. User accounts with no product privilege for CA Network Flow Analysis are deleted.
- User accounts that are associated with custom domains will be associated with the default domain instead.
- If the user account 'nqadmin' exists and has a product privilege that is lower than Administrator, this user account acquires the Administrator product privilege.
You cannot add new users or edit user account settings after you unregister.
- Roles:
- Custom and default roles are retained and continue to be associated with user accounts.
- Groups: Retained if the following conditions are met:
- The group is a default group in CA NetQoS Performance Center or is a group that was pushed up to CA NetQoS Performance Center. 'Dynamic groups,' for example, cross-product groups, are deleted.
- The group has contents--that is, the group is not empty.
Custom and default groups require cleanup on the Manage Groups page in CA Performance Center after you unregister and register with the newer software. The following changes may occur:
- Some group names change slightly. For example, the group 'All Interfaces' is renamed 'Interfaces.'
- Structures may flatten so that a group that was nested under another group is not nested.
- Groups may be relocated:
A custom group that originally was shown on the Manage Groups page under All Groups/System Groups/Data Sources/ReporterAnalyzer is under Network Flow Analysis in the new group tree. The new location is All Groups/Inventory/Data Sources/Network Flow Analysis.
If the custom group originally was not under ReporterAnalyzer, it is moved to sit under Network Flow Analysis.
- Duplicate groups may be created.
- Empty custom groups are deleted.
- SNMP profiles: SNMP profiles from NetQos Performance Center 6.1 are retained with no changes in their status.
- Single Sign-On (SSO) customizations: LDAP SSO customizations are retained. Limited testing indicates that other SSO customizations are also retained.
- Review your records of the customizations in CA NetQoS Performance Center or CA Performance Center, such as:
- User accounts and their roles, product permissions, groups, and domain access
- Custom roles and standard roles that have been customized, including any assignments for top-level menus, dashboards, and dashboard menus
- Group structure and naming conventions
- Custom domains and their contents, such as groups, devices, interfaces, SNMP profiles, report folders, AS names, protocol names, ToS labels, and IP addresses
Remember that these elements may require checking, restructuring, or restoration.
- Open the Data Source List: Click Admin, NetQoS Settings group, Data Sources.
- Select the Reporter Analyzer or CA Network Flow Analysis data source.
- Click Delete.
