Previous Topic: Modify the FirewallNext Topic: Synchronize System Time (Windows)
Upgrade or Register with CA Performance Center
If you previously unregistered from NetQoS Performance Center or CA Performance Center and you have completed the CA Network Flow Analysis upgrade, the next step is to register CA Network Flow Analysis as a data source for CA Performance Center 2.2.00. This topic describes the registration steps.
If you have not unregistered and you have CA Performance Center 2.1.00 currently installed, perform the CA Performance Center upgrade to version 2.2.00 now. For instructions, see the "Upgrade Procedures" section in the CA Performance Center Installation Guide.
  1. Log in to the CA Performance Center console as a user with the Administrator role.
  2. Navigate to the Manage Data Sources page.
    The Manage Data Sources page displays the current list of registered data sources.
  3. Click Add.
    The Add Data Source dialog opens.
  4. Select CA Network Flow Analysis from the Source Type list.
    Note: All CA products that can be registered as CA Performance Center data sources are shown in the Source Type list. The list is not filtered to show installed products.
  5. Select the data source status. Select Disabled if you want to delay polling of this data source while still registering it.
    Note: No data from this data source is reported until you edit the data source to select the Enabled status. Views from this data source display a message stating, "No data to display".
  6. Enter the Host Name: Use the IP address or DNS hostname of the NFA console server.
  7. Enter the port to use when contacting the data source. The port that you enter depends on the protocol you select.
    For more information, see the CA Single Sign-On User Guide.
  8. Select the protocol to use to contact the data source. Select https if your network is using SSL for communications. Verify that you have configured the system correctly before you select the https option.
    Note: SSL can be used for communications between CA Performance Center and the data source products. For more information, see the CA Single Sign-On User Guide.
  9. (Optional) Enter a Display Name for the data source.
    By default, the data source type and the hostname are combined to create the display name. You can supply another name here. For example, instead of NetworkFlowAnalysis@xxx.x.x.xx, you can name the data source NetworkFlowAnalysis_NewYork.
  10. Click Save to register the data source.
    The Data Source List shows the CA Network Flow Analysis deployment that you registered.
  11. Review the results in the CA Performance Center Console and make any adjustments that are needed. Review the list of potential changes that are described in the topic about unregistering. For example, revise the following elements as needed:
  12. Check the effects of your revisions in the NFA console. For example, review the following locations:
