Previous Topic: Disable Unneeded ServicesNext Topic: Unregister from CA Performance Center
Prevent False Positive Events
We recommend that you create an empty TrapConfiguration key in the Windows Registry to prevent the SNMP service from logging false positive events.
  1. Log in as a user who is a member of the Administrators group.
  2. Open a command prompt window.
  3. Run the following command:
    reg add HKLM\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration
    If the command executes successfully, the return value is: "The operation completed successfully."
    The TrapConfiguration registry key is created in the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters.
