CA Network Flow Analysis 9.1.2 supports the upgrades that are described in the following table.
FROM Version |
TO Version |
RA 9.0.161 NPC 6.1.x* |
Standalone 3-tier |
NFA 9.1.2 CA PC 2.2.00* |
Standalone 2-tier |
Distributed 3-tier |
RA 9.1.00 CA PC 2.0.00* |
Standalone 2-tier |
Standalone 2-tier |
Distributed 2-tier |
NFA 9.1.1 CA PC 2.0.00* or 2.1.00 |
Standalone 2-tier |
Standalone 2-tier |
* If you are registered with NetQoS Performance Center 6.1.x or CA Performance Center 2.0.00 before the upgrade, you unregister and register again with CA Performance Center 2.2.00 after the CA Network Flow Analysis upgrade. If you are registered with CA Performance Center 2.1.00 before the upgrade, you upgrade your installation of CA Performance Center before the CA Network Flow Analysis upgrade. For more information, see the following topics:
CA NetQoS ReporterAnalyzer 9.0.161 is the minimum software version that you can upgrade directly to CA Network Flow Analysis 9.1.2. If you have earlier software (CA NetQoS ReporterAnalyzer 8.3.16 Update 2 or 9.0), upgrade to 9.0.161 before you proceed. For more information on meeting this requirement, see the Upgrade Instructions for ReporterAnalyzer 9.0 and 9.0 SP1 on CA Support.
Notes:
