Previous Topic: Performing Advanced AdministrationNext Topic: Mapping Priorities
Map Applications
You can combine traffic from an application that uses several ports into one port. By mapping the application traffic into a single port, you make it easy to report the total traffic for the application. To create application mappings, use the Administration functions to:
For example, suppose you want want to map traffic to a target port in the following situations:
More information:
Mapping Priorities
Create a Host Application Mapping Rule
Create a Subnet Application Mapping Rule
Create an All (ToS) Application Mapping Rule
