Previous Topic: Configure Global Settings for Application MappingNext Topic: Create a Host Application Mapping Rule
Create a Subnet Application Mapping Rule
Create a Subnet application rule to combine traffic that originates from a particular subnet and mask. The application rule lets users easily report the total traffic that is identified with an application.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
      The Application Definitions page opens.
  2. Verify that Application Mapping is the selected value for Rules.
  3. Click Add Rule.
    The Add Application Mapping dialog opens.
  4. Verify that Subnet is selected as the rule type at the top of the dialog. (Subnet is selected by default.)
    The Add Application Mapping dialog displays the options for a Subnet application mapping rule.
  5. Specify values for the following settings:
    Note: Multiple application mapping rules that have the same protocol and port destination settings will have the same name.
  6. When the values are correct for all the required fields, click Save.
    The Add Application Mapping dialog closes. The new rule is included in the Application Mapping rule list.
  7. (Optional) Run reports to verify that all of traffic on the designated target port fits the rule.
  8. (Optional) Once you notice the effects that new or changed application mapping rules have on reports, you may want to rename the protocol to identify it more clearly for other users.
