Previous Topic: Configure Web Content Expiration on Windows Server 2003Next Topic: Configure the Recycle Bin
Prevent False Positive Events
We recommend that you create an empty TrapConfiguration key in the Windows Registry to prevent the SNMP service from logging false positive events. This topic describes how to perform this step on a system that is running either Windows Server 2008 R2 or Windows Server 2003.
Required/Optional
Operating System
Servers to Configure
Recommended
Windows Server 2003, Windows Server 2008 R2
All servers
  1. Log in as a user who is a member of the Administrators group.
  2. Open a command prompt window.
  3. Run the following command:
    reg add HKLM\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration
    If the command executes successfully, the return value is: "The operation completed successfully."
    The TrapConfiguration registry key is created in the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters.
