Interface Reports › Interface Report Types › Top N Conversations Report
A Top N Conversations report provides information about the hosts that generate the most traffic on the selected interface. This report includes information about the total data in the conversations.
To display a Top N Conversations report, start from an interface report.
- Display an interface report in either of the following ways:
- Locate and click an interface on the Interfaces page.
- Click an interface link in an existing view--for example, on the Enterprise Overview page.
- Select Conversations from the report type menu at the top-left corner of the page.
- Make sure that the report scope is set to Top N Conversations. The Top N Conversations link should appear next to the report type setting.
The report page is updated to show a conversation summary pie chart by default.
- (Optional) Change the data presentation type and the data measurement type by using the Presentation options.
- (Optional) Change the reporting period: Open the Timeframe dialog by clicking the timeframe link.
The reporting period is the most recent 24-hour period by default.
Display an Interface Report for a Single Conversation
To drill down to details about a specific conversation, click one of the conversation links in the Top N Conversations view. A report opens, which you can configure to show any of the following data:
You can view this type of report in Details mode or Protocols mode, which have the following options:
- Details mode: Charts of rate, volume, or utilization data in any combination of the following views:
- Last Hour (displayed by default).
- Last 2 Hours (displayed by default).
- Last 8 Hours (displayed by default).
- Daily (displayed by default).
- Weekly.
- Monthly.
- Yearly.
- Protocols mode Trend Chart or Summary Table: Rate, volume, or utilization for the protocols that the conversations used. You see the data coming into the interface and the data going out from the interface.
- Protocols mode Stacked Trend Chart: Data for all protocols that the conversations used (coming into and going out of the interface).
To return to the summary view of all conversations on the interface, click the link that is named for the currently selected conversation and click Select Top N Conversations.
Find Comparable Views in CA Performance Center
You can display the following conversation views in the CA Performance Center console:
- Top Conversations (Bar): Add views of the following types to a custom dashboard: In (inbound data), Out (outbound data), and Total (both inbound and outbound data).
- Top Conversations (Pie): Look for the built-in view on the IP Performance tab of the Interfaces Pages. You also can add views of the following types to a custom dashboard: In (inbound data), Out (outbound data), and Total (both inbound and outbound data).
- Top Conversations (Table): Add Rate, Volume, and Utilization views to a custom dashboard.
