Previous Topic: Specify a Custom Start and End Time
Next Topic: Analyze Interface Report Data
Set the Presentation Options
You can use the Presentation menu to choose the way data is presented in a drilldown Interface report.
To open the Presentation menu, click the gray bar on the left edge of the page, as illustrated in the following example.
To open the Presentation menu, click the gray bar on the left side of the page.
The Presentation menu opens and gives you access to the options that are appropriate for the selected report type. The display options in the top part of the menu may include a one of the following report types:
The selected presentation format determines which metric options are available. For example, if you choose a trend plot as the display type, you can choose rate, volume, or utilization for the metric.
Set the Display Option
Display options determine the presentation of the data in the report views. Each Interface report has a default display type, but you can use the Presentation options to change the display type. The display types that are available depend on the report.
Set the Rate, Volume, Utilization Option
Interface reports support the display of rate, volume, and utilization metrics. The metrics available for the report depend upon the type of data included in the report, and sometimes the selected display option.
Show Other Option
When you display a Top-N report for protocols, hosts, and conversations, you can include data for items other than the top ten. To include the other items, select the Show Other check box in the Presentation options. The data for the other protocols, hosts, or conversations is then rolled up and assigned a label of Other.
