To define a Custom Report, you must specify at least one interface or interface group to supply data for the report. In the Select Interfaces page of the Custom Report wizard, you can select interfaces from the Interface Index or you can select interfaces by group. When you select an interface group, all interfaces in the group and any child groups are included in the report.
You can save the Custom Report definitions you create and edit existing reports as your reporting needs change. You can delete interfaces or temporarily exclude interfaces from the report.
