You can review the Report Definition Summary of a Custom Report to ensure that the report definitions are appropriate. From the Report Definition Summary page, you can access the Custom Report Wizard pages and can modify the report.
Note: Select a report that is not currently in execution--a report that does not have the status Running.
For example, click Interface Filters, Protocol Filters, or ToS Filters to add new filters or change existing filter settings.
Also See: Set Up Custom Reports
The Reports list opens and the modified report shows a status of Queued. When the report has been regenerated and is ready to be viewed, the status displays as Complete.
When you modify a scheduled report, it is queued to be generated at the next scheduled runtime.
